Api session event editor overlay set geotiff
API Endpoint: api/session/event/editoroverlay/set_geotiff/
Description: Change the GeoTIFF displayed by a specified GeoTIFF Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a GeoTIFF Overlay)
1 REQUIRED (GEO_TIFF Integer ID or multiple values in array [1, 2, 3]) Unique GeoTIFF IDs
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_geotiff/", options)
