Api session event editor overlay save grid
API Endpoint: api/session/event/editoroverlay/save_grid/
Description: Create a copy of each specified Overlay. The copies will have the same Settings and Attributes, but can be edited independently of the originals.
| 0 | REQUIRED | (OVERLAY Integer ID or multiple values in array [1, 2, 3]) | Overlay ID |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/save_grid/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/save_grid/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/save_grid/", options)
