Api session event editor netload add and set node
API Endpoint: api/session/event/editornetload/add_and_set_node/
Description: Add And Set Node
| 0 | REQUIRED | (NET_LOAD Integer ID) | Net Loads | |
| 1 | REQUIRED | (Point with crs: EPSG:3857) | Point |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658662.9477977725, 6799324.385269615 ]
'Curl example multi item POST
[ 1, {
"type" : "Point",
"coordinates" : [ 658677.373374558, 6799410.596656252 ]
'JavaScript example POST
body: '[ 1, { "type" : "Point", "coordinates" : [ 658662.9477977725, 6799324.385269615 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857", options)
