Api session event editor measure set terrain height
API Endpoint: api/session/event/editormeasure/set_terrain_height/
Description: Set the inner height of Terrain Spatial of a Measure.
| 0 | REQUIRED | (MEASURE Integer ID) | Measure IDs | |
| 1 | REQUIRED | (Integer number) | Terrain Spatial ID | |
| 2 | REQUIRED | (Floating point number) | Height value |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_terrain_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 59 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_terrain_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 38 ]'JavaScript example POST
body: '[ 1, 1, 59 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_terrain_height/", options)
