Api session event editor measure add grid
Revision as of 12:03, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormeasure/add_grid/
Description: Add a new Grid Spatial to a Measure.
0 REQUIRED (MEASURE Integer ID) Measure ID
200 Grid Spatial ID
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_grid/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add_grid/", options)
