Api session event editor map set height overlay
API Endpoint: api/session/event/editormap/set_height_overlay/
Description: Update Elevation Model from Grid Overlay
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID | |
| 1 | OPTIONAL | (Integer number) | Timeframe (optional) |
| 200 | Integer (Amount of sectors updated) |
curl 'https://engine.tygron.com/api/session/event/editormap/set_height_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editormap/set_height_overlay/", options)
