Api session event editor levee set is relative increase
Revision as of 12:03, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorlevee/set_is_relative_increase/
Description: Set Is Relative Increase
0 REQUIRED (LEVEE Integer ID) Levees
1 REQUIRED (true, false) Boolean true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_is_relative_increase/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_is_relative_increase/", options)
