Api session event editor levee set default width
API Endpoint: api/session/event/editorlevee/set_default_width/
Description: Set Default Width
| 0 | REQUIRED | (LEVEE Integer ID) | Levees | |
| 1 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_default_width/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 77 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_default_width/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 52 ]'JavaScript example POST
body: '[ 1, 77 ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_default_width/", options)
