Api session event editor levee set angle degrees
Revision as of 12:03, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorlevee/set_angle_degrees/
Description: Set Angle Degrees
0 REQUIRED (LEVEE Integer ID) Levees
1 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_angle_degrees/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 74 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_angle_degrees/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 14 ]'
JavaScript example POST
 body: '[ 1, 74 ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_angle_degrees/", options)
