Api session event editor global add
API Endpoint: api/session/event/editorglobal/add/
Description: Add new Global
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorglobal/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''JavaScript example POST
body: ''
fetch("https://engine.tygron.com/api/session/event/editorglobal/add/", options)
