Api session event editor cinematic add keypoint with parameters
API Endpoint: api/session/event/editorcinematic/add_keypoint_with_parameters/
Description: Add KeyPoint With Parameters
| 0 | REQUIRED | (CINEMATIC_DATA Integer ID) | Cinematic Datas | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Float[] | |
| 3 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Float[] | |
| 4 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Float[] |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_with_parameters/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1.0, 1.0, 1.0 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_with_parameters/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ] ]'JavaScript example POST
body: '[ 1, 1, 1.0, 1.0, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_with_parameters/", options)
