Api session event editor area generate sewer areas
Revision as of 12:01, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorarea/generate_sewer_areas/
Description: Generate Sewer Areas for Neighborhoods
0 REQUIRED (Integer number) Degree of Urbanization
1 REQUIRED (Floating point number) Sewer Storage (M) for Neighborhood older than 1965
2 REQUIRED (Floating point number) Sewer Storage (M) for Neighborhood younger than 1965
3 REQUIRED (Floating point number) Pump speed (m/H)
4 REQUIRED (String) Water Level Attribute
200 Integer (Number of generated Sewer Areas)
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_sewer_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 79, 82, 41, "Water Level Attribute" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_sewer_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 62, 63, "Water Level Attribute" ]'
JavaScript example POST
 body: '[ 1, 79, 82, 41, "Water Level Attribute" ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_sewer_areas/", options)
