Api session event editor area add with attribute
API Endpoint: api/session/event/editorarea/add_with_attribute/
Description: Add With Attribute
| 0 | REQUIRED | (String) | String | |
| 1 | REQUIRED | (Floating point number) | Double |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", 71 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", 88 ]'JavaScript example POST
body: '[ "Text", 71 ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/", options)
