Api session event editor area add group
API Endpoint: api/session/event/editorarea/add_group/
Description: Add Group
| 0 | REQUIRED | (String) | Attribute name to group Areas by |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorarea/add_group/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Attribute name to group Areas by"'JavaScript example POST
body: '"Attribute name to group Areas by"'
fetch("https://engine.tygron.com/api/session/event/editorarea/add_group/", options)
