Api session event editor area set attribute
API Endpoint: api/session/event/editorarea/set_attribute/
Description: Set Area Attribute value
0 REQUIRED (AREA Integer ID or multiple values in array [1, 2, 3]) Areas
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Attribute Values
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorarea/set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 1.0 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorarea/set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST
fetch("https://engine.tygron.com/api/session/event/editorarea/set_attribute/", options)
