Api session items levees
Revision as of 09:14, 10 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/levees/
Edit items with events described at Api session event editor levee.
Default Query:
https://engine.tygron.com/api/session/items/levees/?f=JSON&token=API_TOKEN
Example Response:
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/levees/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/levees/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/levees/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/levees/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/levees/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/levees/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/levees/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/levees/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/levees/?f=ZIPSMILE&token=API_TOKEN
Api Model Levee
API Model description of Levee
Name Type Description
angleDegrees double
defaultHeightM double
defaultWidthM double
description String
fixedSize boolean
id int
imageName String
imageVersion int
name String
relativeIncrease boolean
sideFunctionID int Function ID
topFunctionID int Function ID
useExistingFunction boolean
version int
