Api session items scenarios
API Endpoint: /api/session/items/scenarios/
Edit items with events described at Api session event editor scenario.
Default Query:
https://engine.tygron.com/api/session/items/scenarios/?f=JSON&token=WEB_TOKENExample Response:
"attributes" : null,
"description" : "",
"events" : [ ],
"id" : 0,
"limitNeighborhoodIDs" : [ ],
"limitType" : "DEFAULT",
"maquetteOverride" : null,
"name" : "Scenario",
"restartTestrun" : true,
"version" : 2
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/scenarios/?version=100&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/scenarios/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/scenarios/size/?token=API_TOKENScenarios (GeoJSON):
https://engine.tygron.com/web/scenarios.geojson?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/scenarios/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/scenarios/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/scenarios/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/scenarios/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/scenarios/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/scenarios/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/scenarios/?f=ZIPSMILE&token=API_TOKENApi Model CodedEvent
API Model description of CodedEvent
| Name | Type | Description |
| id | int | |
| parameters | Object[] |
Api Model LimitType
API Enumeration description of LimitType
| Name | Description |
| DEFAULT | |
| NEIGHBORHOODS | |
| MEASURE_NEIGHBORHOODS |
Api Model Scenario
API Model description of Scenario
| attributes | Map<String,double[]> | |
| description | String | |
| events | CodedEvent[] | |
| id | int | |
| limitNeighborhoodIDs | int[] | Neighborhoods ID |
| limitType | LimitType | |
| maquetteOverride | Map<String,double[]> | |
| name | String | |
| restartTestrun | boolean | |
| version | int |
