Ground water level area (Subsidence Overlay)
Revision as of 12:11, 9 June 2026 by Frank@tygron.nl (talk | contribs)
This functionality is deprecated and will be removed in the future.
Ground water level areas are areas which can be used to define the initial ground water level, when detailed raster data of ground water depths is not available.
  • Water level areas and subsidence areas can also be ground water level areas at the same time.
