Api session items zones
API Endpoint: /api/session/items/zones/
Edit items with events described at Api session event editor zoning.
Default Query:
https://engine.tygron.com/api/session/items/zones/?f=JSON&token=API_TOKEN
Example Response:
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/zones/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/zones/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/zones/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/zones/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/zones/?crs=LOCAL&token=API_TOKEN
bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/zones/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/zones-foo/?crs=3857&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/zones/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/zones/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/zones/?f=HTML&token=API_TOKEN
JSON:
GEOJSON:
https://engine.tygron.com/api/session/items/zones/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/zones/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/zones/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/zones/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/zones/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/zones/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/zones/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/zones/?f=ZIPSMILE&token=API_TOKEN
Api Model Category
API Enumeration description of Category
Name Description
SOCIAL
NORMAL
LUXE
ROAD
PAVED_AREA
EDUCATION
HEALTHCARE
PARK
NATURE
INDUSTRY
OFFICES
OTHER
SENIOR
UNDERGROUND
SHOPPING
AGRICULTURE
LEISURE
STUDENT
GARDEN
INTERSECTION
BRIDGE
Api Model CategoryZone
API Model description of CategoryZone
Name Type Description
allowedCategories Category[] Category[]
attributes Map<String,double[]>
center Point Point
excelID int Excel Sheet ID
excelUpdated boolean
id int
maquetteOverride Map<String,double[]>
name String
outline Outline
parentZoneID int Zone ID
permitterID int Stakeholder ID
polygons MultiPolygon MultiPolygon
sourceIDs int[] Sources ID
version int
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model MultiPolygon
API Model description of MultiPolygon
type String MultiPolygon
coordinates double[][][][] array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z]
Api Model Outline
API Enumeration description of Outline
Name Description
NONE
SIMPLE
DASHED
Api Model Point
API Model description of Point
type String Point
coordinates double[] x, y, (optional) z
Api Model Zone
API Model description of Zone
center Point Point
id int
name String
outline Outline
version int
