Api session items buildings
API Endpoint: /api/session/items/buildings/
Edit items with events described at Api session event editor building.
Default Query:
https://engine.tygron.com/api/session/items/buildings/?f=JSON&token=API_TOKEN
Example Response:
  "addressIDs" : [ ],
  "attributes" : {
    "NUM_CARS" : [ 67.38087166666666 ],
    "NUM_TRUCKS" : [ 0.9162670833333333 ],
    "NUM_VANS" : [ 2.1849445833333334 ],
    "NWB_ID" : [ 3.83289109E8 ]
  "center" : {
    "type" : "Point",
    "coordinates" : [ 659437.6623386738, 6798652.514593948, 46.724 ]
  "customGeometries" : null,
  "demolisherID" : -1,
  "functionID" : 436,
  "id" : 0,
  "maquetteOverride" : null,
  "measureID" : -1,
  "modelVersion" : 0,
  "name" : "Leeuwerikstraat",
  "overrideCategories" : null,
  "overrideDecals" : null,
  "ownerID" : 0,
  "permitReceived" : null,
  "predecessorID" : -1,
  "sections" : [ {
    "floors" : 1,
    "id" : 1,
    "outerLines" : null,
    "polygons" : {
      "type" : "MultiPolygon",
      "coordinates" : [ [ [ [ 659436.7739362306, 6798649.869141218 ], [ 659436.8259085856, 6798650.018546752 ], [ 659437.111756538, 6798650.632408647 ], [ 659437.3602493604, 6798651.083873241 ], [ 659438.0277692949, 6798652.069625167 ], [ 659438.8187235727, 6798652.961186732 ], [ 659439.7184949687, 6798653.740694189 ], [ 659440.7124662581, 6798654.395155717 ], [ 659440.9447177196, 6798654.523449671 ], [ 659431.573452458, 6798649.869141218 ], [ 659436.7739362306, 6798649.869141218 ] ] ] ]
    "roofPolygons" : null,
    "roofShape" : null,
    "skeletonLines" : {
      "type" : "MultiLineString",
      "coordinates" : [ [ [ 659438.6563099633, 6798653.128456033 ], [ 659436.6748639288, 6798651.507730316 ], [ 659436.106416296, 6798650.932843714 ] ] ]
    "slantingRoofHeightM" : null
  "sourceIDs" : [ 3, 21 ],
  "state" : "READY",
  "upgradeID" : -1,
  "upgradeOwnerID" : -1,
  "version" : 13
  "addressIDs" : [ ],
  "attributes" : {
    "NUM_CARS" : [ 35.873599999999996 ],
    "NUM_TRUCKS" : [ 0.5231566666666666 ],
    "NUM_VANS" : [ 0.9715766666666666 ],
    "NWB_ID" : [ 6.00382077E8 ],
    "TRAFFIC_LANES" : [ 1.0 ]
  "center" : {
    "type" : "Point",
    "coordinates" : [ 659137.9540087318, 6798657.919180244, 51.186 ]
  "functionID" : 436,
  "id" : 1,
  "measureID" : -1,
  "modelVersion" : 0,
  "name" : "Duivenstraat",
  "ownerID" : 0,
  "sections" : [ {
    "floors" : 1,
    "id" : 1,
    "polygons" : {
      "coordinates" : [ [ [ [ 659135.0240672185, 6798652.409035658 ], [ 659136.6904308507, 6798653.388291852 ], [ 659163.1524802279, 6798665.762982272 ], [ 659160.6172037853, 6798671.284503788 ], [ 659145.0108800596, 6798664.07891896 ], [ 659143.7505504508, 6798663.525143152 ], [ 659140.9813984107, 6798662.7423868 ], [ 659138.0205983117, 6798662.450071175 ], [ 659133.9537615327, 6798662.797601979 ], [ 659131.3356541493, 6798663.486167734 ], [ 659128.1848301273, 6798664.850307606 ], [ 659130.793192694, 6798651.405419985 ], [ 659135.0240672185, 6798652.409035658 ] ] ] ]
    "roofShape" : null,
    "skeletonLines" : {
      "coordinates" : [ [ [ 659161.858043761, 6798668.5822057305 ], [ 659149.1670443238, 6798662.7066593375 ], [ 659138.1521533353, 6798658.589881861 ], [ 659130.8906408596, 6798657.099073017 ], [ 659129.8040938128, 6798656.504698323 ] ] ]
  "state" : "READY",
  "upgradeID" : -1,
  "version" : 14
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/buildings/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/buildings/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/buildings/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/buildings/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/buildings/?crs=LOCAL&token=API_TOKEN
bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/buildings/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
ROAD:
https://engine.tygron.com/api/session/items/buildings-road/?crs=3857&token=API_TOKEN
ROAD+FOO:
https://engine.tygron.com/api/session/items/buildings-road-foo/?crs=3857&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/buildings/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/buildings/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/buildings/?f=HTML&token=API_TOKEN
JSON:
GEOJSON:
https://engine.tygron.com/api/session/items/buildings/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/buildings/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/buildings/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/buildings/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/buildings/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/buildings/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/buildings/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/buildings/?f=ZIPSMILE&token=API_TOKEN
Api Model Building
API Model description of Building
Name Type Description
addressIDs int[] Addresses ID
attributes Map<String,double[]>
center Point Point
customGeometries CGLink[]
demolisherID int Stakeholders ID
functionID int Function ID
id int
maquetteOverride Map<String,double[]>
measureID int Measures ID
modelVersion int
name String
overrideCategories Category[] Category[]
overrideDecals Map<FaceType,float[]>
ownerID int Stakeholders ID
permitReceived Map<int,Boolean>
predecessorID int Buildings ID
sections Section[] Section[]
sourceIDs int[] Sources ID
state TimeState Timestate
upgradeID int Upgrade Types ID
upgradeOwnerID int Stakeholders ID
version int
API Model description of CGLink
geometryID int Custom Geometry ID
primary boolean
Api Model Category
API Enumeration description of Category
Name Description
SOCIAL
NORMAL
LUXE
ROAD
PAVED_AREA
EDUCATION
HEALTHCARE
PARK
NATURE
INDUSTRY
OFFICES
OTHER
SENIOR
UNDERGROUND
SHOPPING
AGRICULTURE
LEISURE
STUDENT
GARDEN
INTERSECTION
BRIDGE
Api Model FaceType
API Enumeration description of FaceType
Name Description
BASEMENT
GROUND
EXTRA
TOP
ROOF
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model MultiLineString
API Model description of MultiLineString
Api Model MultiPolygon
API Model description of MultiPolygon
type String MultiPolygon
coordinates double[][][][] array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z]
Api Model Point
API Model description of Point
type String Point
coordinates double[] x, y, (optional) z
Api Model Section
API Model description of Section
floors int
id int
outerLines MultiLineString MultiLineString
polygons MultiPolygon MultiPolygon
roofHeightM double
roofPolygons GeometryCollection
roofShape float[]
skeletonEnd Point Point
skeletonLines MultiLineString MultiLineString
skeletonStart Point Point
slantingRoofHeightM double
Api Model TimeState
API Enumeration description of TimeState
Name Description
NOTHING
WAITING_FOR_DATE
REQUEST_PLOT_OWNER_APPROVAL
REQUEST_ZONING_APPROVAL
REQUEST_CONSTRUCTION_APPROVAL
CONSTRUCTION_APPROVED
CONSTRUCTION_DENIED
PENDING_CONSTRUCTION
CONSTRUCTING
READY
PENDING_UPGRADE
WAITING_FOR_DEMOLISH_DATE
REQUEST_DEMOLISH_ZONING_APPROVAL
REQUEST_DEMOLISH_APPROVAL
DEMOLISH_APPROVED
DEMOLISH_DENIED
PENDING_DEMOLISHING
DEMOLISHING
DEMOLISH_FINISHED
