Api session event participant stakeholder set location
API Endpoint: api/session/event/participant/stakeholder_set_location/
Description: Set the location of a Stakeholder in the 3D world.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (Point with crs: EPSG:3857) Location of the Stakeholder on the map as Point
2 REQUIRED (true, false) Ping others (show them my location) true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/stakeholder_set_location/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658664.097686127, 6799353.934353643 ]
}, true ]
Curl example multi item POST:
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658675.8142039079, 6799312.457825559 ]
}, true ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658664.097686127, 6799353.934353643 ]}, true ]'
fetch("https://engine.tygron.com/api/session/event/participant/stakeholder_set_location/?crs=3857", options)
