Api session event participant net cluster set load attribute
API Endpoint: api/session/event/participant/net_cluster_set_load_attribute/
Description: For each Net Load of a Net Cluster, set the value of the Attribute.
0 REQUIRED (STAKEHOLDER Integer ID) Initiating Stakeholder ID
1 REQUIRED (NET_CLUSTER Integer ID) Net Cluster ID
2 REQUIRED (String) Attribute name
3 REQUIRED (Floating point number) Value
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Attribute name", 66 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Attribute name", 36 ]'
JavaScript example POST:
 body: '[ 1, 1, "Attribute name", 66 ]'
fetch("https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attribute/", options)
