Api session event logic net lines set attribute
API Endpoint: api/session/event/logic/net_lines_set_attribute/
Description: For each Net Line, set the value of the Attribute.
0 REQUIRED (NET_LINE Integer ID or multiple values in array [1, 2, 3]) Array of Net Line IDs
1 REQUIRED (String) Attribute
2 REQUIRED (Floating point number) Value
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/net_lines_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute", 21 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/net_lines_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], "Attribute", 47 ]'
JavaScript example POST:
 body: '[ 1, "Attribute", 21 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_lines_set_attribute/", options)
