Api session event editor stakeholder set start budget
API Endpoint: api/session/event/editorstakeholder/set_start_budget/
Description: Set Start Budget
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholders | |
| 1 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/set_start_budget/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 8 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/set_start_budget/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 31 ]'JavaScript example POST:
body: '[ 1, 8 ]'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/set_start_budget/", options)
