Api session event editor setting wizard finished
API Endpoint: api/session/event/editorsetting/wizard_finished/
Description: Wizard Finished
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsetting/wizard_finished/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''JavaScript example POST:
body: ''
fetch("https://engine.tygron.com/api/session/event/editorsetting/wizard_finished/", options)
