Api session event editor netload add and set node
API Endpoint: api/session/event/editornetload/add_and_set_node/
Description: Add And Set Node
0 REQUIRED (NET_LOAD Integer ID) Net Loads
1 REQUIRED (Point with crs: EPSG:3857) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658749.2462691191, 6799399.591587309 ]
Curl example multi item POST:
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658660.3849110163, 6799438.674591794 ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658749.2462691191, 6799399.591587309 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857", options)
