Api session event editor measure set cost
API Endpoint: api/session/event/editormeasure/set_cost/
Description: Set the Costs of a Measure of a particular Cost type (construction, demolition) and wether it is fixed or Cost per cubic meter.
| 0 | REQUIRED | (MEASURE Integer ID) | Measure ID | |
| 1 | REQUIRED | (Enumeration) | Cost Type | CONSTRUCTION |
| 2 | REQUIRED | (Floating point number) | Cost in valuata | |
| 3 | REQUIRED | (true, false) | Fixed (if false, Cost per cubic meter) | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_cost/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "CONSTRUCTION", 75, true ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_cost/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "CONSTRUCTION", 88, true ]'JavaScript example POST:
body: '[ 1, "CONSTRUCTION", 75, true ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_cost/", options)
