Overlay
Revision as of 13:59, 25 August 2015 by Joris@tygron.com (talk | contribs)
Overlays
An overlay is a layer drawn over a visualization to illustrate different properties. They do not contain all the information of a given visualization, but serve as a supplement to a base. By adding these properties onto the same view, the additional information can immediately be made understandable in the same way. A reason to split information off into other layers in this fashion can be to avoid overwhelming a user with too much information.
How overlays are implemented in the Tygron Engine
Overlays are implemented in the Tygron Engine as part of the interface. Properties such as ownership and zoning are important pieces of information to the player, but would be very overwhelming to display at all times. Instead, a player can activate on overlay to make these pieces of information visible. In principle, all spatially varied information is accessible as an overlay.
Available overlay types
Multiple types of overlay exist in the Tygron Engine. All overlays which are available by default when creating a project are described below.
City
The default view. This displays the project detail area in natural colors. Hovering over a location displays properties of the construction or land type in that location.
Zoning
This overlay is available by default. This overlay displays the zoning plan for the entire project detail area. This is helpful when considering indicators which are scored per zone, and when looking to construct a building which is restricted to certain zones.
Ownership
This overlay is available by default. This overlay displays the ownership across the entire project detail area, using each stakeholder's colors. This is important when considering what stakeholder may construct a building where, or whom to negotiate with for land transactions.
Optional overlay types
Livability
Taffic Flow
Underground
Safety Zone
Heat
Quality of Life
This overlay becomes available for each stakeholder with the livability indicator. It displays the average livability for each part of the project detail area, giving an indication of where the livability can best be increased.
Water Stress
Terrain Sewer
Terrain Flooding
Terrains
Pipe network Financial
Pipe network Technical
Function Highlight
Custom Color Area's
Vacancy
How to use overlays
To switch to a specific overlay, use the buttons just below the minimap. To switch back to the default view, switch to the "City" overlay.
Adding and removing overlays
