Api session items sounds
Api Session Items Sounds Endpoint: /api/session/items/sounds/
Edit items with events described at Api session event editor sound.
Default Query:
https://engine.tygron.com/api/session/items/sounds/?f=JSON&token=API_TOKENExample Response:
[ ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/sounds/?version=100&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/sounds/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/sounds/size/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/sounds/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/sounds/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/sounds/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/sounds/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/sounds/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/sounds/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/sounds/?f=ZIPSMILE&token=API_TOKENApi Model Sound
API Model description of Sound
| Name | Type | Description |
| background | boolean | |
| filename | String | |
| id | int | |
| loop | boolean | |
| name | String | |
| version | int | |
| volume | double |
