Api session items cinematicdatas
Api Session Items Cinematicdatas Endpoint: /api/session/items/cinematicdatas/
Edit items with events described at Api session event editor cinematic.
Default Query:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=JSON&token=API_TOKENExample Response:
"active" : false,
"animateToStart" : false,
"animateToStartPoint" : false,
"endType" : "SIMPLE",
"id" : 0,
"keyIndex" : 0,
"keyPoints" : [ {
"description" : "Welcome to Api-test, first a flytrough to make you familiar with the area.",
"direction" : {
"x" : 285.356,
"y" : 51.329113786870785,
"z" : 285.356
"eventBundlesIDs" : [ ],
"id" : 7,
"location" : {
"x" : 426.777,
"y" : 148.56966681707473,
"z" : 426.777
"pause" : true,
"soundID" : -1,
"time" : 4.0,
"up" : {
"x" : 0.0,
"y" : 1.0,
"z" : 0.0
"description" : "",
"direction" : {
"x" : 300.0,
"y" : 55.20368105299929,
"z" : 250.0
"id" : 6,
"location" : {
"x" : 500.0,
"y" : 144.91636178848591,
"z" : 250.0
"pause" : false,
"soundID" : -1,
"time" : 4.0,
"up" : {
"x" : 0.0,
"y" : 1.0,
"z" : 0.0
"description" : "",
"direction" : {
"x" : 285.356,
"y" : 56.87688383945199,
"z" : 214.644
"id" : 5,
"location" : {
"x" : 426.777,
"y" : 151.54411246559837,
"z" : 73.223
"pause" : false,
"soundID" : -1,
"time" : 4.0,
"up" : {
"x" : 0.0,
"y" : 1.0,
"z" : 0.0
"description" : "You are now entering the neighborhood Klarenbeek.",
"direction" : {
"x" : 250.0,
"y" : 49.06819152832031,
"z" : 200.0
"id" : 4,
"location" : {
"x" : 250.0,
"y" : 157.1198216847011,
"z" : 0.0
"pause" : false,
"soundID" : -1,
"time" : 4.0,
"up" : {
"x" : 0.0,
"y" : 1.0,
"z" : 0.0
"description" : "You are now entering the neighborhood Sonsbeek-Noord.",
"direction" : {
"x" : 214.644,
"y" : 43.67911892845517,
"z" : 214.644
"id" : 3,
"location" : {
"x" : 73.223,
"y" : 146.51884792162025,
"z" : 73.223
"pause" : false,
"soundID" : -1,
"time" : 4.0,
"up" : {
"x" : 0.0,
"y" : 1.0,
"z" : 0.0
"description" : "You are now entering the neighborhood Hazegrietje.",
"direction" : {
"x" : 200.0,
"y" : 42.794297238613694,
"z" : 250.0
"id" : 2,
"location" : {
"x" : 0.0,
"y" : 151.31980790483192,
"z" : 250.0
"pause" : false,
"soundID" : -1,
"time" : 4.0,
"up" : {
"x" : 0.0,
"y" : 1.0,
"z" : 0.0
"direction" : {
"x" : 214.644,
"y" : 44.550744256307915,
"z" : 285.356
"id" : 1,
"location" : {
"x" : 73.223,
"y" : 136.94186375357887,
"z" : 426.777
"pause" : false,
"soundID" : -1,
"time" : 4.0,
"up" : {
"x" : 0.0,
"y" : 1.0,
"z" : 0.0
"description" : "You are now entering the neighborhood Onder de Linden.",
"direction" : {
"x" : 250.0,
"y" : 51.85581020598716,
"z" : 300.0
"id" : 0,
"location" : {
"x" : 250.0,
"y" : 146.50577267733487,
"z" : 500.0
"pause" : false,
"soundID" : -1,
"time" : 4.0,
"up" : {
"x" : 0.0,
"y" : 1.0,
"z" : 0.0
"description" : "",
"direction" : {
"x" : 250.0,
"y" : 50.98006374277967,
"z" : 250.0
"id" : 8,
"location" : {
"x" : 250.0,
"y" : 603.5534057617188,
"z" : 251.0
"pause" : false,
"soundID" : -1,
"time" : 4.0,
"up" : {
"x" : 0.0,
"y" : 1.0,
"z" : 0.0
"name" : "Welcome Cinematic",
"stakeholderID" : -1,
"version" : 1,
"voice" : ""
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/cinematicdatas/?version=100&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/cinematicdatas/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/cinematicdatas/size/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=ZIPSMILE&token=API_TOKENApi Model CinematicData
API Model description of CinematicData
| Name | Type | Description |
| active | boolean | |
| animateToStart | boolean | |
| animateToStartPoint | boolean | |
| endType | EndType | |
| id | int | |
| keyIndex | int | |
| keyPoints | KeyPoint[] | |
| localClientOnly | boolean | |
| name | String | |
| stakeholderID | int | |
| version | int | |
| voice | String |
Api Model EndType
API Enumeration description of EndType
| Name | Description |
| SIMPLE | |
| LOOP | |
| WAIT_AT_END |
Api Model KeyPoint
API Model description of KeyPoint
| description | String | |
| direction | Vector3d | |
| eventBundlesIDs | int[] | Event Bundles ID |
| id | int | |
| location | Vector3d | |
| pause | boolean | |
| soundID | int | Sounds ID |
| time | double | |
| up | Vector3d |
Api Model Vector3d
API Model description of Vector3d
| x | double | |
| y | double | |
| z | double |
