Api session event participant action menu set active
Revision as of 14:49, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/action_menu_set_active/
Description: Set a Category active for a Stakeholder.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (ACTION_MENU Integer ID) Action Menu ID
2 REQUIRED (true, false) Active true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/action_menu_set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST:
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/participant/action_menu_set_active/", options)
