Api session event logic session release
Revision as of 14:49, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/session_release/
Description: Release a client from a Session using its client token.
0 REQUIRED (String) ClientToken
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/session_release/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"ClientToken"'
JavaScript example POST:
 body: '"ClientToken"'
fetch("https://engine.tygron.com/api/session/event/logic/session_release/", options)
