Api session event logic net line set attribute
Revision as of 14:49, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/net_line_set_attribute/
Description: Set the Attribute of a Net Line to the provided value.
0 REQUIRED (NET_LINE Integer ID) Net Line ID
1 REQUIRED (String) Attribute
2 REQUIRED (Floating point number) Value
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/net_line_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute", 6 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/net_line_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute", 11 ]'
JavaScript example POST:
 body: '[ 1, "Attribute", 6 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_line_set_attribute/", options)
