Api session event logic areas set attributes
API Endpoint: api/session/event/logic/areas_set_attributes/
Description: Per entry in the array, set the value of the Attribute for the Area.
| 0 | REQUIRED | (AREA Integer ID or multiple values in array [1, 2, 3]) | Array of Area IDs | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Array of Attributes | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Array of Values | |
| 3 | OPTIONAL | (true, false) | Update Indicators (optional) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/areas_set_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Array of Attribute 1", 1.0 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/areas_set_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Array of Attribute 1", "Array of Attribute 2", "Array of Attribute 3" ], [ 1.0, 2.0, 3.0 ] ]'JavaScript example POST:
body: '[ 1, "Array of Attribute 1", 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/logic/areas_set_attributes/", options)
