Api session event editor weather append attribute
Revision as of 14:48, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorweather/append_attribute/
Description: Appended to existing Weather Attribute value
0 REQUIRED (WEATHER Integer ID or multiple values in array [1, 2, 3]) Weathers
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Attribute Values appended to existing values
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorweather/append_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 1.0 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorweather/append_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST:
fetch("https://engine.tygron.com/api/session/event/editorweather/append_attribute/", options)
