Api session event editor stakeholder set start budget
Revision as of 14:48, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorstakeholder/set_start_budget/
Description: Set Start Budget
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
1 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/set_start_budget/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 37 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/set_start_budget/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 85 ]'
JavaScript example POST:
 body: '[ 1, 37 ]'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/set_start_budget/", options)
