Api session event editor stakeholder set short name
API Endpoint: api/session/event/editorstakeholder/set_short_name/
Description: Set Short Name
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholders | |
| 1 | REQUIRED | (String) | String |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/set_short_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'JavaScript example POST:
body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/set_short_name/", options)
