Api session event editor setting set timestamp format
Revision as of 14:47, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorsetting/set_timestamp_format/
Description: Set timestamp format
0 REQUIRED (String) String
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_timestamp_format/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Text"'
JavaScript example POST:
 body: '"Text"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_timestamp_format/", options)
