Api session event editor parametric remove plot attributes
Revision as of 14:47, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorparametric/remove_plot_attributes/
Description: Remove Plot Attributes
0 REQUIRED (PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) Parametric Design
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Plot
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute name
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorparametric/remove_plot_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Attribute name 1" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorparametric/remove_plot_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ "Attribute name 1", "Attribute name 2", "Attribute name 3" ] ]'
JavaScript example POST:
 body: '[ 1, 1, "Attribute name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorparametric/remove_plot_attributes/", options)
