Api session event editor panel set text
API Endpoint: api/session/event/editorpanel/set_text/
Description: Set Text
| 0 | REQUIRED | (PANEL Integer ID) | Panels | |
| 1 | REQUIRED | (String) | String |
| 200 | String (String) |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_text/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'JavaScript example POST:
body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_text/", options)
