Api session event editor panel set attention
API Endpoint: api/session/event/editorpanel/set_attention/
Description: Set Attention
| 0 | REQUIRED | (PANEL Integer ID) | Panels | |
| 1 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_attention/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'JavaScript example POST:
body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_attention/", options)
