Api session event editor panel add global
API Endpoint: api/session/event/editorpanel/add_global/
Description: Add Global
| 0 | REQUIRED | (PANEL Integer ID) | Panels | |
| 1 | REQUIRED | (GLOBAL Integer ID or multiple values in array [1, 2, 3]) | Globals |
| 200 | String (String) |
curl 'https://engine.tygron.com/api/session/event/editorpanel/add_global/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/add_global/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/add_global/", options)
