Api session event editor overlay add result child
Revision as of 14:46, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/add_result_child/
Description: Add a specified Result type as a child Overlay to a specified Grid Overlay. The child Overlay's result will be based on the parent's calculation, allowing you to get multiple types of results from the same calculation.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a Grid Overlay with Result types)
1 REQUIRED (String) Result type for new child Overlay (must be a valid result for the parent Overlay type)
200 Integer (Overlay ID)
curl 'https://engine.tygron.com/api/session/event/editoroverlay/add_result_child/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Result type for new child Overlay" ]'
JavaScript example POST:
 body: '[ 1, "Result type for new child Overlay" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/add_result_child/", options)
