Api session event editor netload remove node
Revision as of 14:46, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetload/remove_node/
Description: Remove Node
0 REQUIRED (NET_LOAD Integer ID) Net Loads
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/remove_node/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editornetload/remove_node/", options)
