Api session event editor netload remove address
API Endpoint: api/session/event/editornetload/remove_address/
Description: Remove Address
| 0 | REQUIRED | (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) | Net Loads | |
| 1 | REQUIRED | (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) | Addresses |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/remove_address/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetload/remove_address/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/remove_address/", options)
