Api session event editor netload add and set node
Revision as of 14:46, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetload/add_and_set_node/
Description: Add And Set Node
0 REQUIRED (NET_LOAD Integer ID) Net Loads
1 REQUIRED (Point with crs: EPSG:3857) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658785.7893312306, 6799384.417414808 ]
Curl example multi item POST:
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658670.0566414552, 6799309.74881702 ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658785.7893312306, 6799384.417414808 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857", options)
