Api session event editor netload remove
Revision as of 14:46, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetload/remove/
Description: Remove existing Net Load
0 REQUIRED (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) Net Loads
curl 'https://engine.tygron.com/api/session/event/editornetload/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetload/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editornetload/remove/", options)
