Api session event editor levee set default height
API Endpoint: api/session/event/editorlevee/set_default_height/
Description: Set Default Height
| 0 | REQUIRED | (LEVEE Integer ID) | Levees | |
| 1 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_default_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 84 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_default_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 25 ]'JavaScript example POST:
body: '[ 1, 84 ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_default_height/", options)
