Api session event editor global set point
API Endpoint: api/session/event/editorglobal/set_point/
Description: Set Point
| 0 | REQUIRED | (GLOBAL Integer ID) | Globals | |
| 1 | REQUIRED | (Point with crs: EPSG:3857) | Point |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658700.8518859306, 6799395.765153028 ]
'Curl example multi item POST:
[ 1, {
"type" : "Point",
"coordinates" : [ 658645.7611896273, 6799421.1680979915 ]
'JavaScript example POST:
body: '[ 1, { "type" : "Point", "coordinates" : [ 658700.8518859306, 6799395.765153028 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorglobal/set_point/?crs=3857", options)
