Api session event editor functionoverride reset
API Endpoint: api/session/event/editorfunctionoverride/reset/
Description: Reset
| 0 | REQUIRED | (FUNCTION Integer ID) | Functions |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorfunctionoverride/reset/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorfunctionoverride/reset/", options)
